I just got my braces and noticed that the brackets are colored??? My ortho asked if i wanted color and i said no. Im just wondering if this is permanent? Im a 20 year old male and i look rather silly with red, green, and orange on my teeth.
Is it just like a little dot on the actual bracket? My brackets had those little colored dots at first but they come off after a few times brushing your teeth. I think they are just there to help the ortho with placement and stuff.
Andromeda wrote:Is it just like a little dot on the actual bracket? My brackets had those little colored dots at first but they come off after a few times brushing your teeth. I think they are just there to help the ortho with placement and stuff.
Yep, I was wondering the same thing at first with mine. But yes - what the above poster said. The color came off after a few times brushing - thank goodness.
Braces on - April 22, 2009
Length - 14 months
Type - Damon (Metal top & Bottom)
Age - 38 Mom of 2
