I've been braced for 3 weeks. However I become aware that I am clenching my teeth during the night. I am curious to know if this could be causing the muscles in my neck and shoulders to go into spasm? My neck is so stiff I cannot tip my head up or down and my shoulders are rigid. (this makes driving abit precarious) I just can't think what else this could be down too...
Has anyone else had a problem with their neck/shoulders due to clenching teeth? Or am I just odd!
Teeth Clenching
Hi Briggsy,
I have had my braces almost 3 months now and still clench my teeth. If you search the posts, you will see a number of us do this as well. It is completely normal. I think we clench our teeth because it feels good. We are not aware of this while we are sleeping. Sometimes I clench so hard it wakes me up from a sound sleep
I knew I had some clenching problems when awake, like when I was cold or focusing on something, but I never knew I did it in my sleep until braces!! I started waking up in the morning and suddenly squeeking my teeth against each other as my jaw relaxed. It doesn't happen every morning, but it was an uncomfortable surprise the first time it happened.
Update: went to Ortho yesterday for advice. Apparently it is the jaw muscle thingy (can't remember the proper terminology). Typical... trust me to be difficult. I've grAnyway he has tightened my top braces (and I'm only 3 weeks in). The ligs are now replaced by white wire ties... a few teeth are abit sore this morning but not too bad atall. The only advice about the teeth clenching was about the pain relief or removing the bottom arch - which I obviously don't want to do.... Anyway, my neck is less stiff while I'm popping the pills.... thanks for listening to me rant... :0)
I clench my teeth when I sleep now as well. I didn't do it before I got braces so I am assuming I do it because of the braces. I have had my braces for just over a month now and I don't think I clench my teeth as much anymore, or not as badly anyway because it isn't waking me up like it was. I didn't get stiff or anything because of it, my jaw would be a little bit sore when I would wake up but that was it.
