When did you first start noticing your teeth moving? It's been almost 1 month and I don't really notice anything at all! They are all sore so I feel that they are moving. I only really notice difference in my teeth when I eat. I've been taking pictures but it all looks the same.
Also I noticed that my archwire in the middle isn't exactly straight, its kind of bent, do you think that matters? The archwire hasn't moved at all in the middle but the lady said it will go straight with heat or something. When she put the archwire in my mouth to fit it in the middle she bent it. Do you think it's something to worry about? It's very slight not big at all and there hasn't been much movement, I figure it will try to go straight on its own like the rest of the wire.
Teeth moving & archwire placement
Some offices like to put a bend into the midline area when using initial flexible wires. This will prevent the wire from sliding too much in either direction, minimizing the chance that a wire will end up poking you at the back. Shouldn't be anything to worry about :).
Good luck.
Good luck.
Dr. Jason Tam
http://www.mcosmiles.com
