Has anyone ever been had orthodontia treatment using the Damon Braces/Brackets?
Thanks in advance for any comments!
I have had them for 9.5 months on top and almost 6 months bottom, no pain issues, no troubles with them at all.
Now i don't have any other type of braces to compare them with so i can't really say with first hand experience that they are any better then standard braces. But from my experience with them i definitely recommend them. I had very crowded teeth on the bottom and they are almost perfect now not even 6 months later with no extractions.
I've had them for a year now, and so far it's been a good experience. Not major pain, no extractions and fast movement. But I don't have any reference for comparison, so I can't say they are any better that other types of braces. I chose this ortho because I could avoid extractions and palate appliances, not because of damons. For me, the only negative part is that they are metal and not clear, a part from that, they're ok. At least for me they are working great with little discomfort.
braced 07/02/08, braces off january 2010
sentence: 18 months, upper and lower damons + elastics
Bonded+essix retainers
My story: http://www.archwired.com/phpbb2/viewtopic.php?t=28298
- RamboSally
