What toothbrush/electronic/sonic toothbrush that is good?
gracey82
#1 Post by gracey82 »
Hi guys,
Just wondering if anyone has any recommendations on any toothbrush/electronic/sonic toothbrush you are using and that you will recommend ??
thanks,
gracey82
changes09
#2 Post by changes09 »
I started a sonicare toothbrush thread. Read some of the comments on there. Many people (including myself) love the sonicare brand.
Audra
#3 Post by Audra »
I used to own a sonicare. I stopped using it because I didn't really like it. When I got braced my ortho gave me an Oral B Professional electric toothbruth and I absolutely LOVE it.
Jim C
#4 Post by Jim C »
GUM makes a special "ortho" line of toothbrushes. They're extremely soft, with a small head and the brushes are cut like a V (to fit on either side of the brackets). I had to special order them in but at 3.99 (CDN$) they're a deal.
trillium
#5 Post by trillium »
I like my Oral B Professional....
04/09/09- Consult, 04/21/09- Spacers in, 04/23/09- Braces on, 06/01/09- Extractions
06/25/09- First Adjustment (new wire, but same size- all the way to bck molars- after extractions)
08/20/09- Second adjustment (same size wire but got Powerchains top and bottom!!!)
10/02/09- 3rd adj (same size wire, new powerchain, started elastics)
12/10/09- 4th adj. (same size wire, new powerchain, same elastics)
02/11/10- 5th adj.
