In reading and being told what the situation really is I now know that the average overjet in a normal occlusion is 2mm, and not what I'd previously thought. This is from the edge of the upper incisors back to the front surface of the lower incisors, and of course requires teeth of the right thickness and at the correct inclination. But my next and possibly equally dumb question is why is there this slight overjet? I mean if it's the average in the 'normal' population it must be there for a reason.
I'm wondering if it's something to do with the fact that if you lean your head forwards – or lift your head when you're lying on your back – your lower jaw slides forwards a bit? Given teeth are meant to overlap vertically, if you didn't have this horizontal gap the lower incisors would surely slide into and catch on the upper incisors. Wouldn't this pressure cause the teeth to move over time?
Or is there some other reason?
![Confused :?](./images/smilies/icon_confused.gif)
