Why are my back lower molars like 1-2mm higher than the other teeth, they didnt used to be like that? They are not banded, could it be my impacted wisdom teeth that is causing this?
Vyse wrote:Why are my back lower molars like 1-2mm higher than the other teeth, they didnt used to be like that? They are not banded, could it be my impacted wisdom teeth that is causing this?
All my teeth are changing in heights in response to the braces. if you are braced too.. then i would imagine your molars are reacting that way to the braces. it's supposed to be all evened out in the end, from what i'm reading here.
