Hi Everyone,
I have my first adjustment next Tuesday and was wondering about how long it will take.
Also, do you think I'll be okay to go straight back to work afterward, or should I tell the boss I'm taking the afternoon off?
Thanks for all you help!
Patty
First Adjustment Next Week
everyone is different when it comes to pain. For me, I have never had to stay home from work after adjustments. I found that it was most painful when I first got the braces on, but after each adjustment, it just feels tighter, and its nothing I tylenol cant fix. You may need to have softer foods for lunch, but I wouldnt get worked up about the pain after the adjustment, its not as bad as you expect it to be.
Spacers in Aug. '09
MARA without elbows on Aug/09
Braces on Nov. 20/09
Elbows for MARA in Feb. 25/10
Braces off August 26, 2010!
Essix Retainers
my story: http://archwired.com/phpbb2/viewtopic.php?t=33571
Essix Retainers
