Snack Foods for the Road
I'm traveling with my family on a 8 hour charter bus to a family reunion and I need some good ideas for snacks that I can buy to take on the bus with me.
- TumbleDryLow
Pretty much anything that's convenient to travel with would be OK. Of course you want to stay away from anything really hard or sticky (toffee, caramel), but I would think pretzels, chips, chocolate would be fine. Just take some water so you can swish. Pack a travel kit with toothbrush, toothpaste and a cup so you can brush at the bathroom rest stops.
I take a lot of road trips so snacks is something that's important to me.
I take a small cooler with me and always make sure to carry some yogurt and a plastic spoon. The reason for this is when I finish a meal I eat some yogurt because it seems to take some of the food bits with it down to the stomach. My mouth feels cleaner at least. Ice cream works well for this too.
But then be sure to brush as soon as you can!
I discovered this wonderful snack called "pirate booty" its like cheetos kind of different flavor, but they are soft and easy to chew. I like the veggie one a lot.
