What to expect from ortho with acky molar filling
streetmaster
#1 Post by streetmaster »
I've had so much trouble from one of the lower wisdom teeth on the left side, from crowding and from crossbite issues. I've had it filled since last year and it still tingles some when i chew, and is sencitive to sugary products.
I've had the tooth delt with because of a highspot because it was hitting wrong, they remove the filling, and placed a medicated filling in it, and the filled it the second time.
No more highspot but still tingles a little while i chew. But if im not eating anything for a lot period of time, it feels fine.
Im set up to go in this week to start my treatments, i guess to start off with would be exray and spacers.
Is this somthing to be consurned about, or is it common?
Meemoo
#2 Post by Meemoo »
I would guess that they would want to take the wisdom tooth/teeth out if it's causing you that many problems...
