that loose tooth feeling
I've had my braces for about 1 1/2 years, I had big gaps to close from extractions as well as alot of teeth that were turned, so my teeth had long distances to move, I still occassionally have that really loose clicking tooth feeling. How long does it take untill teeth firm up in place? Is it only when you have the retainer in place, or does it happen when you still have your braces in?
Re: hi
why does somebody always say that? couldn't find it. I read often but don't post THAT much. If no one ever posted the same thing twice it would be a short forum.sadpanda wrote:Hi -
This question was asked on another thread somewhere...you might want to look. .
04/09/09- Consult, 04/21/09- Spacers in, 04/23/09- Braces on, 06/01/09- Extractions
06/25/09- First Adjustment (new wire, but same size- all the way to bck molars- after extractions)
08/20/09- Second adjustment (same size wire but got Powerchains top and bottom!!!)
10/02/09- 3rd adj (same size wire, new powerchain, started elastics)
12/10/09- 4th adj. (same size wire, new powerchain, same elastics)
02/11/10- 5th adj.
02/11/10- 5th adj.
quote
I said that because there were already a lot of replies to the other similar thread and I thought you could get more information faster than waiting for people to respond to the same question again. Also - your question resembled that of a recent post. If the last person who responded to "the loose tooth feeling" had been in 2009 or something, I wouldn't have mentioned anything.
