Really useful mini brushes
Just discovered TePe interdental brushes.
They're tiny, really cheap, have a little case and can easily be carried round everywhere. Very useful for any bits of food stuck in unwanted places when you're out for a meal.
Has anyone else seen these or what else do people use?
Braced for 19 months 2 weeks and 2 days.
- footpounds
I was just researching these in the "dental do-dads" forum on here. They have a ton of the interdental brushes and reviews for them posted there. I havent' chosen which one to buy yet, but I want to! not sure we have that brand in the US.
Update: 4-2013 Back in Brackets
lower braces: 3/2/10
hyrax palate expander: 3/29/10
upper braces: est. 6/2010 (8/6/10 actual)
bone plate surgery: 1/2011 actual
bone plate removal: 7/2011 actual
Debracing: 10-25-11 ACTUAL!!! advanced hawley retainer
Rebracing: 4-3-13...front teeth rotated #2s lifted.
VA5 wrote:I wish they would sell mini waterpik's. something you can recharge, and fill with a little bit of water, and after you eat you can go to the restroom and just powerwash the teeth quickly. THAT would be great.
They do have something like that, but from what I understand, the power is rather weak and it hasn't gotten very good product reviews. I'm sure you can find it online if you search.
I can not find my favorite proxy brushes anywhere. The full brush was on a blue handle with a clear holder.
They only ones I can find now are the skinny brushes. I hate them because they aren't sturdy and when you use them, the bend really easy.
Isn't it typical to find a product you like and then it becomes
non-existent...
non-existent...
