yellowing teeth
yellowing teeth
hi i only had my braces put on last week and have been cleaning everyday and brushing three times a day. have noticed in the last couple of days my teeth seem to be looking yellow especially at the tops. im not sure why. im cleaning well and am trying my best not to miss any spots. wondering why this might be happening. also im not using a whitening toothhpaste which i did used to sometimes.
- BraceFace2o1o
Hey fleur26, someone made a very similar thread about the same kind of thing the other day... here it is, maybe there is an answer for you there viewtopic.php?t=37310
I think certain toothpastes and mouthwashes (with a certain ingredient) can cause teeth to stain.
- BraceFace2o1o
Do you use mouthwash? I think they are one of the culprits to cause staining of teeth.fleur26 wrote:thanks might change my toothpaste and see how i go
I've been searching for one that doesn't contain Cetylpyridinium chloride as apparently this can cause staining of the teeth (Dentist can remove it). I managed to fine one in my local Sainsburys and that was a Sensodyne one.
- NervousNewbie
I have this same problem and am actually the one who made a thread very similar to this one. I can't help but wonder if my mouthwash is causing this. I use Listerine anti-cavity with fluoride (green).Maya wrote:I found that the mouthwash was the culprit for my teeth staining! Now I dilute them in water before rinsing. When I got my braces, the ortho had me rinse my mouth in diluted mouthwash too....now I know why.
Braced September 23, 2010
Debraced February 20, 2014
Estimated Treatment Time: 24 months
Actual Treatment Time: 41 months
My Journey
