staining teeth
staining teeth
hi ive noticed since my braces have been on my teeth have beenb picking my stains easier. my hygenist says it just means i need to use an interspace brush to give them a good clean and get around my brackets. anyone else find they seem to attract stains? and any tips would be fab!
Re: staining teeth
i meant been picking UP stains easier!fleur26 wrote:hi ive noticed since my braces have been on my teeth have beenb picking my stains easier. my hygenist says it just means i need to use an interspace brush to give them a good clean and get around my brackets. anyone else find they seem to attract stains? and any tips would be fab!
- jensceana73
Use one of these......
Uploaded with ImageShack.us
I just did a post in my story as to how, and why.....I love these!!!!!
(I also use a Sonic Care, and Water Pik)
I have the small ones that Jen showed a pic of and i love using those between my back teeth. It actually feels really good. But i use a thicker one for between the brackets and they clean really well, sometimes I use my whitening toothpaste with them.
https://cart.jbutler.com/store.php?crn=285
These are all really great. They have the different sizes and handles. I use the handle and refills. Theres a link for that on the right. I bought a small packet to start, picked the ones i liked then bought in bulk. Walmart doesn't really carry a lot of these.
There is a replaceable tip one from Oral B with a long handle and I love it for doing back teeth. I only have that at home though, my dental kit that I carry around has those small ones. I go through each space between my teeth and wire before and after a brush and amazing what you dislodge even after you think you have brushed really well!
My back teeth has moved (large space) and the brush fitted in great between the teeth with molar bands, I dislodge heaps of stuff there.
I started with the really thin one but since my teeth has started moving, I found the xmas tree ones much better for cleaning between the wires and wire tie twisty bits.
