NHS waiting list question?
bubsy08
#1 Post by bubsy08 »
If I ring up the hospital that I will be having the treatment at, will they tell me where I am on the list?
venom
#2 Post by venom »
i see your last post was june 09 so where are you on your progress?
bubsy08
#3 Post by bubsy08 »
venom wrote:i see your last post was june 09 so where are you on your progress?
Still waiting for braces
Loztredders
#4 Post by Loztredders »
I'd say it's definatly worth a try to ring them up and ask, they probably will give you a rough estimate of waiting time rather than tell you exactly where you are on the list. I have been told that the wait for nhs orthodontics for adults can be up to three years though, depending on which area of the UK you're in.
lu lu
#5 Post by lu lu »
Loztredders wrote:I have been told that the wait for nhs orthodontics for adults can be up to three years though, depending on which area of the UK you're in.
I didn't think you could get it done free of charge as an adult. Only children :shock:
For my Braces Story - with photos click here
Wearing Lower Ceramic Brace / Upper Lingual Brace (Incognito) / Sentence 18 - 24 months
Emmauk
#6 Post by Emmauk »
You can have it done through the nhs if you meet certain criteria, if your interested look on the nhs site and it gives measurements to put you into a "serious" category, my bite was i think 13mm out.
I am well entitled to the nhs braces but didnt want to wait 2 more years and also the braces would be metal which i didnt want.
bubsy08
#7 Post by bubsy08 »
i have a 10mm overbite so will be having braces and surgery to move my bottom jaw forward, I had an op to remove my bottom wisdom teeth and 2 others on the bottom, then I went back and they said I am ready for braces, i am now on the waiting list.
