Dent and stain from overlapped teeth... Help!!
fishtails
#1 Post by fishtails »
As my overlapped teeth are getting spaced out, I've noticed a dent and unsightly stain where the teeth used to overlap. It looks I have a huge piece of food stuck in my teeth all the time!
What can I do? Has anyone had this happen to them?
anniegirl
Re: Dent and stain from overlapped teeth... Help!!
#2 Post by anniegirl »
Hi, I have noticed stains with mine too, I am going to my dentist in a couple of weeks, and just hoping a good professional clean will do the trick!!
haywire
#3 Post by haywire »
teeth scaling will do the trick, as it did for the back of my lower teeth today
MY STORY
Braces on 23/07/2009
Braces off 10/12/2010
part time essix hater.
fishtails
#4 Post by fishtails »
I'm so relieved that there's a solution!
Does the hygenist at the Orthodontist's office do scaling?
My stain is behind the wire, so I think it should be done when I get my wires changed. I'm afraid a dentist/ortho wouldn't be able to get around the wire otherwise.
haywire
#5 Post by haywire »
i don't think your ortho will do that, but he doesen't have too, you can go to any dentist to do it, it's also cheap and it takes about 10-15 minutes
MY STORY
RHOyally Braced
#6 Post by RHOyally Braced »
Had the same thing, a normal dental cleaning will get rid of it. My hygenist goes around the wire when she does my cleaning.
~RHOyally Braced~
