Just curious, does anyone else have any problems flossing their back two upper teeth? I can barley reach that far, I used to have issues before braces.. but now with braces.. the brackets which hold the end of the wire seems to take up all space.
My ortho suggested trying to floss there, but she also said not to force it. Because if the floss has no room to enter..most likely no food will either..i am thinking.
Plumcore wrote:My ortho suggested trying to floss there, but she also said not to force it. Because if the floss has no room to enter..most likely no food will either..i am thinking.
Thanks! hoping you're right! I brush really well there.. just can't reach back to get the floss through.
@Wongohk, I'll ask my ortho about it at my next adjustment if I can't figure it out by then. - thanks!
The first few months I couldn't figure out how to floss some of my back teeth, but things have been shifting around and now I can floss some that couldn't be done before. Just sayin'... I was also told not to try and force floss if too tight.
Has anyone had issues with the floss getting caught on the metal bands? Whenever I floss my left back tooth the floss somehow always gets caught on the metal band on the tooth in front of it and i have a hard time pulling the floss out. Sometimes it comes out with no problems, other times the floss breaks and leaves some behind wrapped around part of the band and I have to pull it out.
Yep, I usually have that problem on my back brackets. I have to make sure they don't get hooked on anything.. or else I end up shredding the floss as I'm trying to pull it through. Sometime I end up flossing my bracket instead of my gums :p
me too! right now, i can't get into floss the back teeth either.....i was able to do it w/o braces but now.....what i'm doing is using a proxy brush back there, i figure it's better than nothing??
