Front Teeth
scorr77
Front Teeth
#1 Post by scorr77 »
I've noticed that my front teeth are not aligned as straight as they were before I got braces about 6 wks ago..... I'm not sure why but my left front tooth has moved a lil bit out more than my right front tooth. Has anyone ever had this issue and is this normal?
footpounds
Re: Front Teeth
#2 Post by footpounds »
Don't draw any conclusions about your teeth's movement, especially so earlier into your treatment. Your teeth can, and will, make some movements that might seem alarming but relax. It's nothing abnormal and everything will work out as time goes on. Trust in your orthodontist!
seriousthinker
Re: Front Teeth
#3 Post by seriousthinker »
Hi, mine are doing some crazy things at the mo. Looks like my ortho is pushing them together but I trust that in the long run it's all part of the plan!
SlimZippy
Re: Front Teeth
#4 Post by SlimZippy »
Don’t worry. They move in all sorts of directions as the forces change but on average over time they converge to the right place.
Damon & ICE brackets for 11 months in 2010/2011 @ 34 : Before and after pictures here
tashay1985
Re: Front Teeth
#5 Post by tashay1985 »
I second what every one else is saying, I wouldnt worry too much it is still the beginning phases and your teeth with move constantly. I had a freak out when a gap popped up between my 2 front teeth and when my back molars became more really really crooked but over time theyve straightened out again. when i asked my Ortho's assistants, they said not to worry that sometimes your teeth may look a little worse before they start to look better. It was definitely true in my case lol you can check out my blog to see what I mean :paperbag:
