According to an orthodontist I was in contact with, Damon braces does not only straighten the teeth but also widen the upper arch. Apparently this improves the smile.
Does anyone know to what extent is this true? Do they really widen the upper arch? More so than ceramic braces?
Would Damon braces potentially give a better result than ceramic braces which do not widen the upper arch?
Thanks for any info!
Damon braces v Ceramic braces
Re: Damon braces v Ceramic braces
Yes it is true. and Cermanic braces don't widen the arch the wire is tied in like as in traditional braces requiring extractions and if you want clear that bad ot with Damon Clear if your ortho has it if not that's ok, Damon is better it does expande I can feel my arch expanding
Jenn Medeiros
I have damon metal braces top and bottom. It's been almost 5-6 months since I been braced and I notice a significant change in my arch. Like BracedSurgeryStudent stated you can feel when your arch expand. It's weird and cool at the sametime.
I too, have Damon braces, and have had them for about 6 weeks. I agree that they do widen the arch, which is exactly what I need. My upper teeth tilt inwards, and i have noticed a significant change in my smile and teeth positioning. My smile is wider and my teeth are moving a lot. It does feel a bit strange, and I am pleased so far with the results.
i have damon clear upper and damon metal lower, i sure hope they widen well because i need it
i am happy with them so far. the clear uppers arent irritating my gums as much as the metal are!
tkna wrote:I have damon metal braces top and bottom. It's been almost 5-6 months since I been braced and I notice a significant change in my arch. Like BracedSurgeryStudent stated you can feel when your arch expand. It's weird and cool at the sametime.
Yes it is I love having the Damon system. My orthodontist is HIGHLY specialized in it and only offers Damon System which I think is great.
Jenn Medeiros
Indeed they do I noticed my top arch expanding a bit since the teeth are practically straight the bottom is ging to take some work before it will begin to widen. That's excellentkamor wrote:I too, have Damon braces, and have had them for about 6 weeks. I agree that they do widen the arch, which is exactly what I need. My upper teeth tilt inwards, and i have noticed a significant change in my smile and teeth positioning. My smile is wider and my teeth are moving a lot. It does feel a bit strange, and I am pleased so far with the results.
Jenn Medeiros
