I haven't had an adjustment in 12 weeks
Yes I know that is odd but I had foot surgerey in another state and could not get back to my home state as I was physically unable. I finally returned back home last week and had my teeth cleaned and ortho visit the next day. I have had no wire change since last December. Do you think not visiting the ortho for 3 months us going to extend my 24 month sentence? It will be a year in braces this august. I almost had to beg my ortho for a wire change last week. I started to have issues with a molar band in April where it felt it was digging into my gums. Actually it was and developed irritation and redness, bleeding. They took it off last week. I may end up with another spacer around that molar when they replace the molar band. I feel like I have taken several steps back.
Re: I haven't had an adjustment in 12 weeks
I just had my braces put on yesterday and my first adjustment isn't until August 22nd.
![Image](http://tickers.TickerFactory.com/ezt/d/4;10716;96/st/20110601/e/having+braces+put+on%21/k/c9f1/event.png)
- Crazy4Snow
My ortho told me never to miss an appt. and if it's unavoidable and I do have to cancel one to make sure I get in within a week or two or it will prolong my treatment. Hopefully I will never have a situation that will cause me to miss one.
![Image](https://tickers.TickerFactory.com/ezt/d/4;10766;104/st/20130904/e/Since+Braces+Were+Removed/k/c176/event.png)
My story in this forum:
http://www.archwired.com/phpbb2/viewtop ... =9&t=38942
Braced: 4/7/2011
Metal Upper & Lower
Sentence: 18-24 months
Removal Date: 9/4/13
You said you had to beg your ortho to change the wire...did he feel a new wire wasn't necessary? If so, then missing 3 months shouldn't be an issue. My ortho likes to see me every 4-6 weeks. It has been like that since the beginning. It really depends on your case and what he/she is trying to accomplish. I will talk to them if you are really concerned.
I don't think it should be an issue. My adjustments are normally every 10-12 weeks.
![Image](http://tickers.TickerFactory.com/ezt/d/4;29;88/st/20110309/e/I+got+my+braces+on/k/ad72/event.png)
Estimated Treatment Time: 30 Months
