Okay! So, I just got my braces yesterday morning. Tonight, though, I've noticed something rather odd.. My two front teeth are now different lengths! They have always been the same size and length, but after getting my braces, somehow my right front tooth is now noticeably longer than my left. Is this normal, or has anyone experienced this before? This is the weirdest thing! If anyone could be of help or offer some advice, I would be extremely grateful.
Thank you very much!
Two front teeth are now different lengths?
Re: Two front teeth are now different lengths?
Hi
I wouldn't worry about it, its completely normal! My two front teeth are different lengths since having braces and one is even a bit more forward than the other! its all part of the process
I've noticed the same thing, though I can't quite remember if it was like that before the braces..
