Question - re flattening contact points to make space
I've been speaking with a few people at work when they ask me questions about my braces and 'how on earth will they all fit'. I tried to take a picture to illustrate how they are positioned bout if you think about it like that, my two immediate front teeth are fine, looking front on, my left tooth next to it is behind my two front and the one on the right essentially grew alot behind. My ortho has not put a bracket on that one as she needs to make space. In the treatment plan, shes indicated that in order to make space, she will flatten the contact points of the lower anterior teeth to give 4mm space for my crossbite. I dont know what she will do for the front ones. Could anyone please explain to me how teeth are flattened to make space? will it generally involve grinding them down abit when she needs to do them? I'm just on 3 weeks into having braces, they're going ok at the moment :D
Re: Question - re flattening contact points to make space
Could be IPR? That is where they file the edges of your teeth to make room. I had 0.5 mm done either side as the two teeth next to my front teeth wouldnt fit in the gap otherwise. When it had been done I was all happy for a while but the gaps closed very quickly. It doesn't hurt, it didn't bother me at all, the instrument just makes your head vibrate a bit! Then for the next few appts he used like a metal nail file to take a tiny bit more off.
Ha ha It was supposed to say all 'gappy' not 'happy' lol .... Damn autocorrect! ![Smile :)](./images/smilies/icon_smile.gif)
so essentially it sounds like a grinder/drill? i have major drill fear :P
- TumbleDryLow
It can be drill type sander with a disk that spins or a hand file. Most orthos use the drill type. I hate, hate, hate drills as well. I had quite a bit of IPR done between my front teeth then some on the tops of my molars to adjust the contact points of my bite. I won't lie. I found it an uncomfortable experience. But it was over in a few seconds. You'll be fine.
ty for the facts :D was getting a little worried there.
