Midline adjustment
TWild
Midline adjustment
#1 Post by TWild »
My gaps are finally closed and now I'm guessing my orthodontist will level out my teeth and adjust my midline. My top teeth are shifted just a bit to the left and my bottom teeth are shifted to the right. Does anyone know if this part of treatment goes by faster than closing gaps? It seemed like it took forever.
Braced 10-06-2008
De-Braced 11-21-2011 Woohoo!
catgyrl
Re: Midline adjustment
#2 Post by catgyrl »
Congrats on your gap closure!! :jump:
I'm interested to find out this answer, myself. I got my one extraction done in May of last year, and I still have a couple of teeny gaps that need to close, so that's just over a year ago. My ortho started on the leveling portion of my treatment back in January 2011 with elastics, and lemme tell you... it is SLOOOOOOOOWWWW!! One month they look great... next month they're back where they were. One bit of advice: Be VERY diligent with your elastics wear. Follow your ortho's instructions to a "T", or else you'll find yourself in braces even longer than you thought you'd be.
TWild
#3 Post by TWild »
catgyrl wrote:Congrats on your gap closure!! :jump:
Wow, leveling since January? I thought I was only 2 - 3 months out lol.
I thought I would be in braces for 2 years and now I'll be coming up on 3 in October :(
Braced 10-06-2008
catgyrl
#4 Post by catgyrl »
Twild-
I think my leveling case is a more complicated one. I was a thumbsucker, and as a result, the upper teeth on the left side of my mouth are higher than those on my right side, so that's what he's trying to fix.
I'm sorry to hear your "sentence" got extended. I have a strong feeling that mine will, too. But we both know that after all this time, we want them to be as perfect as they can be, especially after forking out all this money.
Good luck to you!
Cathy
TWild
#5 Post by TWild »
catgyrl wrote:Twild-
Good luck to you!
Cathy
Thanks, and good luck to you as well!
Braced 10-06-2008
Chicagogal
#6 Post by Chicagogal »
I'm hoping to find this out myself. I'm in a heavy elastics stage. I started with crowding, not gaps, but a gap has started to open between my two front teeth from elastics working so hard to pull my lowers back and close my bite. My midline is definitely off and I'm not sure what elastic formation will fix it and how long it will take. I'm asking next week at my appt.
Update: 4-2013 Back in Brackets :(
lower braces: 3/2/10
hyrax palate expander: 3/29/10
upper braces: est. 6/2010 (8/6/10 actual)
bone plate surgery: 1/2011 actual
bone plate removal: 7/2011 actual
Debracing: 10-25-11 ACTUAL!!! advanced hawley retainer
Rebracing: 4-3-13...front teeth rotated #2s lifted.
