Flossing with braces
I've been struggling to floss with my braces. The first couple of days of having braces, my teeth were really too sore to floss them, so I didn't. When the pain disappeared, I was able to floss all my teeth except for my lower front teeth (they're too close together) and my upper and lower back teeth. When I tried to floss my lower front teeth, the floss would get stuck and shred inbetween my teeth. I'm unable to floss my back teeth because I can't get my floss threader under the wire. Is there an easier way to floss? I know how important it is, and it has been bothering me that I haven't been able to fully finish flossing.
Thanks in advance!
Thanks in advance!
Re: Flossing with braces
Overtime those teeth will move and it will create space so it will be easier.
Have you tried a thinner floss?
No, I haven't tried a thinner floss. I've just been using the floss that came with my dental cleaning kit.
I've always had crowded teeth that would break floss every single time I used it. Might I suggest you try Crest Glide Threader Floss? It comes in individually wrapped packs of 30. One end of it is stiff (like the end of a shoelace), which you use to thread under your wire so you can floss. It slides through my teeth much more easily than any other floss.
-Cathy
-Cathy
Giving a quick update! I bought the Crest Glide floss yesterday and used it last night. It is amazing! I was able to floss without any problems at all. Thank you all for the suggestions!
Try either Glide Threader Floss or Plackers OrthoPick Flossers. Both are available at DentaKit.com.
I have that same problem as well. My bottom teeth are crowded and it hurts so much to floss. I struggle to get the floss in between my teeth and when I do I am in so much pain. The floss shreds. Right now I still have a very thin piece stuck in either my teeth or bracket. I can't tell. I can only feel it with my tongue and I can't seem to get it out. I end up using anbesol to numb the pain after I floss because it really hurts. I'm going to try the suggestions mentioned.
Flossing was one thing I hated most about having braces. It just takes forever. But, a week into my braces treatment my friend that also had braces recommended that I get a Water Flosser by WaterPik. It's about $50 and I can say it's so worth it. They have a special attachment for braces and it cleans your brackets really well and I use the Classic Jet tip for my gumline. According to the manufacturer is that its 3x more effective than regular flosisng. I seriously love my waterpik... it's so much easier to floss and you also save so much time! It takes about a minute to floss both upper and lower. You should really look into getting one. You'll thank me later. HEHE.
I'll definately start looking into that! Since you have a waterpik, do you only use that or do you floss with regular floss as well?xGa12yx wrote:Flossing was one thing I hated most about having braces. It just takes forever. But, a week into my braces treatment my friend that also had braces recommended that I get a Water Flosser by WaterPik. It's about $50 and I can say it's so worth it. They have a special attachment for braces and it cleans your brackets really well and I use the Classic Jet tip for my gumline. According to the manufacturer is that its 3x more effective than regular flosisng. I seriously love my waterpik... it's so much easier to floss and you also save so much time! It takes about a minute to floss both upper and lower. You should really look into getting one. You'll thank me later. HEHE.
When I'm at home I use my waterpik. But at work or If I'm out somewhere I'll always have floss available just in case I might need it. But I would say I use my waterpik 90% of the time to floss and it gets the job done. If you have a costco around you...I think they have a special right now... You can buy the dual pack for $79. It comes with the Cordless/Travel one and One for your restroom that you keep plugged in. I wish I would've got it there instead. I bought just the cordless one for 50 bucks. But yeah, check it out. You will like it... guaranteed!
I also use the waterpik with the orthodonitc head, though you need to replace them every 2-3 monts because the tip will start to fray. do you also use one of the portable waterpiks for travel or work, I use a SPAMTRONIC SPAMSONIC SPAMONAIDE SPAMSTER SPAM SPAMINATOR one that runs on 2 AA batteries and helps a lot!
*edit* how come when I wrote the company brand it says "spam" instead?
- CountessDeSangre
I don't know but it made me laugh!quiggle wrote:I also use the waterpik with the orthodonitc head, though you need to replace them every 2-3 monts because the tip will start to fray. do you also use one of the portable waterpiks for travel or work, I use a SPAMTRONIC SPAMSONIC SPAMONAIDE SPAMSTER SPAM SPAMINATOR one that runs on 2 AA batteries and helps a lot!
Not sure we're allowed to use some brand names on here. That made me laugh!! It sounds like Rob Schneider's character "Copy Boy" on SNL. He used to do that to people's names.
That was pretty funny! That made me think of the Monty Python skit about Spam!
Thanks for all the suggestions, I really appreciate it!
