Hi all!
I'm new to the forum. Got braces about 4.5months ago at age 22. I had a question for those of you that had or currently has a power chain. Any forum i read on here about power chains dicusses the pain it causes and the quickness of peoples gaps closing with it. I oddly enough have had no pain or discomfort after having mine put on 5 weeks ago on my uppers. I also have had no changes in my gaps. I'm kinda worried they wont close with the lack of change in 5 weeks with a power chain. I have my next adjustment in a week and there wasnt any talk about removing my power chain at this adjustment. Is there different kinds of power chains or something that will close the gaps better? Anyone thats gone thru this I would love it if you post a message about your experience. It may help me understand it all better. Thanks guys for reading my concerns :)
Experiences with wearing a power chain?... I see no changes
Re: Experiences with wearing a power chain?... I see no chan
At your next adjustment, they will probably replace the powerchain. It only keeps it's strength for about 4 weeks, I believe.
I am not sure what kind of gaps you are having closed. Mine is for my 1st premolars that were extracted. Those kind of gaps close about a 1mm a month. I only have soreness for a few days and everything feels normal again.
I have also had a section of 4 front teeth with powerchain to close small spaces. That just made my teeth feel a little sore and tight when I flossed.
Try not to be discouraged and give it time.
Metal brackets & 4 bands on May 12, 2011
4 Premolars Extracted on May 20, 2011
Fully braced on May 25, 2011
My sentence - 24 to 30 months
My Story: http://www.archwired.com/phpbb2/viewtop ... =9&t=39348
TinkB
Believe it or not i actually have all of my teeth, including wisdom teeth. needed no extractions and i still grew up with nearly 2mm gaps between all of the front four teeth (if that makes sense, i dont know all my tech terms as of yet). Weird right? Lol nearly every tech that has done an adjustment on me will exlaim "you have all your teeth, and with room to spare!" haha can get embarrasing.
But i do hope your correct in giving it time and a stronger power chain. Of all the things i wanted to change i really wanted to see my gaps disappear!
I have never had a powerchain, but I can assure you that they will close your gaps! Since you had no extractions, it would make sense to me to assume that your teeth are just not that easy to move. They will put a stronger powerchain next time, and that will for sure produce movement. Don't worry, the gaps will be closed!
There are various strengths of powerchain. It will vary depending on the distance between each link, the colour you choose, as well as the manufacturer. If the correct powerchain is placed, the space will close, but is often not noticeable as you are looking at it on a daily basis. Keeping your tongue out of the spaces will also help them close more easily.
Dr. Jason Tam
http://www.mcosmiles.com
- BraceFace2o1o
My Ortho has made a 'powerchain' out of wire (like sometimes he uses a wire ligature instead of a rubber one) and I've had one of those for the past 2+ months (replaced the other day). It's to close a 2mm (I'm guessing the width) gap between my lower front tooth and the one next to it, I thought because it was made out of wire it would be stronger than a powerchain but it didn't seem to make 1 bit of difference to my gap in 2 months! When he replaced the wire chain on Wednesday it felt really tight and I had quite a bit of discomfort and today I can already see the gap is ever so slightly smaller, no one else would notice just me. So fingers crossed this gap starts closing soon! Even though I get confused as to why it didn't budge in 2 months with the wire 'chain', I am confident the gap will be closed eventually... especially since I have at least another 11 months to go.
Thanks all! I do feel considerably better knowing its a process and the gaps will eventualy close. I think i'll still bring it up with my ortho and be sure that he soon changes my power chain to something stronger. Anxious to see changes lol =)
