Got my braces on today! Will these bite turbos get easier?
tinkc
#1 Post by tinkc »
I got my braces put on this morning!!
I have Damon brackets. Top are clear and bottom are metal. Really no problems right now. I have two bite turbos behind my top 2 front teeth that are annoying the heck out of me! I have a horrible lisp with these things and I think it's making eating even more difficult. I'm praying these things are off sooner than later. Can anyone give me some tips on how to deal with these bite turbos? If it wasn't for them, I really would have no complaints. :BigGrin:
freysmiles
Re: Got my braces on today! Will these bite turbos get easie
#2 Post by freysmiles »
You'll get used to them in a few weeks, and they will bother you a lot less. Thankfully, you'll have them on only as long as you need them.
As annoying as bite turbos are, they do a lot of good things during treatment like keeping you from biting off brackets, unlocking your bite to make treatment faster, and helping to shape your smile, your orthodontist has probably explained all that to you already.
Scott Frey DDS, MSD
Board Certified Orthodontist, FreySmiles Orthodontics
Speaker, Invisalign, Henry Schein Orthodontics
Founder, MorethanSmiles.org
AAOF Vanguard & Keystone Societies
Certificate of Orthodontics/Master's in Dentistry, University of Colorado
Fellow, World Congress of Minimally Invasive Dentistry
Faculty/Fellow, American Academy of Facial Esthetics
Top Writer 2012, '13, Quora
bracemyself23
#3 Post by bracemyself23 »
I'm going to have turbos too. I already have a lisp. This should be fun! :)
kellyb
#4 Post by kellyb »
what exactly are bite turbos? i wonder if i will need them (i am only wearing braces on my bottom arch at the moment, top to be fitted next month)
In braces 07/01/2012 - 29/06/2013
freysmiles
#5 Post by freysmiles »
kellyb wrote:what exactly are bite turbos? i wonder if i will need them (i am only wearing braces on my bottom arch at the moment, top to be fitted next month)
Bite Turbos are just pieces of plastic that are stuck onto your teeth to open up your bite. They are most commonly used to keep you from biting on your braces. Since you already have braces on your bottom teeth, you probably won't get them.
Scott Frey DDS, MSD
kellyb
#6 Post by kellyb »
thanks freysmiles. they sound like a right nightmare!
plugnickel69
#7 Post by plugnickel69 »
Got full ceramics on two days ago. Fortunately, didn't get bite turbos or anything to keep from chewing only on my brackets. Unfortunately, can't chew. Luckily, no pain yet whatsoever.
I wonder if I would be better off with bite turbos???
tinkc
#8 Post by tinkc »
I doubt it, they are so annoying. I'm really hating talking to anyone because of how bad my lisp is with the bite turbos. It's bad enough when people are staring at your mouth trying to see your braces, then you draw that much more attention to yourself with the lisp.
freysmiles
#9 Post by freysmiles »
plugnickel69 wrote:Got full ceramics on two days ago. Fortunately, didn't get bite turbos or anything to keep from chewing only on my brackets. Unfortunately, can't chew. Luckily, no pain yet whatsoever.
Well if you can't chew you won't bite your brackets off ;)
I can't comment on if you'd be better off with bite turbos. They need to go on with a specific purpose (if they will speed treatment, prevent debonds, help develop a smile arc, etc.).
Scott Frey DDS, MSD
plugnickel69
#10 Post by plugnickel69 »
freysmiles: I can chew, but only the upper incisors on the lower incisor brackets, so I can chew them off. Also afraid I may chip my upper incisors.
freysmiles
#11 Post by freysmiles »
plugnickel69 wrote:freysmiles: I can chew, but only the upper incisors on the lower incisor brackets, so I can chew them off. Also afraid I may chip my upper incisors.
Yea you might want to have your orthodontist put on some turbos. The material in the clear brackets is much much harder than your teeth, and will wear them down if you are chewing on the clear braces. To be diplomatic just mention to your orthodontist that you don't like chewing on the brackets and ask them if they can put something on your teeth to open your bite.
Scott Frey DDS, MSD
plugnickel69
#12 Post by plugnickel69 »
Much thanks freysmiles.
