Photos - Day 4 and Day 12.. Slight Progress!!
ashenk224
#1 Post by ashenk224 »
I'm sure I'm not the only one to do this, but I started taking pictures every few days just to see if I made any progress so far. I'm thrilled to see that my teeth are already moving! It's not a huge difference, but you can see the difference in the size of the gap. In both photos I'm biting down on my bite turbos. First one is from today (day 12), second one is from day 4.
Estimated length of treatment: 26 months
Current Debanding Date: 5/28/2014
wildpig
Re: Photos - Day 4 and Day 12.. Slight Progress!!
#2 Post by wildpig »
Might have to draw circles. I am having trouble seeing the differences ;) Actually your teeth look fairly good to start with, at least from these pics. How long do you have to have these on?
BBQ Grill
#3 Post by BBQ Grill »
I see movement on the left side of the pic....but r u sure Ur not biting extra hard on that side? LOL
ashenk224
#4 Post by ashenk224 »
haha. No I'm not biting extra hard. perhaps these two pictures would help (hopefully). The first is day one, the 2nd is one I just took.
the gap where my left lateral incisor is rotated is getting smaller (not by much but I notice it!)
my right lateral incisor has moved down a bit (the archwire is straighter)
I thought I was crazy at first, but after taking many photos I think I'm not haha.
ashenk224
#5 Post by ashenk224 »
Oh and I'm supposed to wear them 26 months... I thought that was kind of long. My ortho said that my top teeth should be aligned in 6-8 months and I don't remember what she said about the bottom. I think she said a year. She also said that after about a year to a year and a half she is going to file down my two front teeth to make them look more proportioned to the rest of my teeth. I had a bad dentist who just filed my two front teeth down after I chipped them and now they look triangular. I assume the lengthy time is because of my overbite? They did say I had to wear by bite turbos about a year.
BBQ Grill
#6 Post by BBQ Grill »
Your two front teeth looks fine but what do I know. Most definitely your wire got straighter... So there has to be some movement. 26 months?.... Eeeek... It took me 7 months to get to where Ur at and I was quoted at 24 months lol...so i got 17 more months to go... I say urs gonna take around 17 months. Maybe even faster
ashenk224
#7 Post by ashenk224 »
I noticed what she meant about my front teeth only because they've been bothering me since my old dentist shaved them down. They used to be quite a bit longer. 17 months would be fantastic! I hope I could have them done in that time too :) I know they're waiting to bracket my lower left canine because I have a recessed gum line on that tooth and the ortho said if they try to move it too soon, I could lose the tooth. They shaved down some of my teeth to make room and once the room is there, they're going to bracket my canine. Not sure when exactly that's going to happen. They put a power chain on the teeth they shaved down and my second molar, so I'm hoping by the time I go in for my first adjustment (June 6th) they'll be able to put a bracket on it. But perhaps that ordeal is what's adding treatment time.
BetsyBug
#8 Post by BetsyBug »
Your teeth look alot like mine do except my lateral incisors on the top are turned in behind my centerals instead of turned out. I have had my braces now for about 5 weeks and I'm seeing some changes but mostly leveling those laterals are going to be bugger to move I think. They have been super sore but they just are resisting turning. When i think about how they move teeth they tip first and then they move the roots to meet up, those teeth need to rotate so they have to move all at once, no tipping really so i think they will be the last to get to where they are going.
I'm sure you are seeing some movement, and pretty soon you will see that those molars will be getting closer together. I didn't think mine would but they are moving and now i have two teeth that collide that didn't before.....
Good luck!!!
Elizabeth
Getting top and bottom traditional metal braces and bite turbos
correcting crowding, overbite, and TMJ on 3/6/2012
Turbos Removed 8/14/2012
Click for my story
brucebadonde
#9 Post by brucebadonde »
Ouch! 26 months?
I've got an eight tooth brace on the top only - for nine months. I only have a problem with my top front 4 - the right main incisor mainly which is pressed back in.
I took a bite into some plasticine before they were fitted and kept it. It seems a good way to measure progress.
ashenk224
#10 Post by ashenk224 »
Yeah 26 months sucks. I remember when I was around 12 and went to the ortho they told me 24 months. I was hoping after 14 years technology would have shortened that time frame, but oh well. I can only hope my teeth move fairly quickly and knock some time off of that :-/
