Hi everyone, this is my first post but after years of following the forum I decided to take the plunge and get "6 month braces" 9 months ago. Long story short, my ortho wanted to take my brace off five weeks ago but I was nowhere near happy with the results. I've lost all confidence in him to be honest. I had one crooked front tooth which was receding behind the tooth beside it (all other teeth were pretty much perfectly aligned). As of now my two front teeth are nowhere near flush. A pic I took this morning is here -
I was so distressed after my appointment yesterday when he moved the bracket on the good, straight front tooth (my right one, left looking in at the pic), to try and fill in the gap BUT......the crooked tooth (my left front tooth, on the right looking in at the pic) is still, and will be, crooked!!
I think if you are paying your money for a service then you should get what you paid for. Simple as that.
If you are unhappy with the result AND there is something that the ortho CAN do to fix it then i think you should bring it to his attention that you are not satisfied.
looking at your gumline, I would say your front teeth are actually well aligned but the shapes of your teeth are obviously making them look off.
I'm obviously not qualified to suggest what you need but I would *think* you need bonding on your smaller of the 2 front teeth so that it matches the other and then it will look flush.
Brace Date: 14th April 2011 Estimated Debrace Date: 14th April 2013 Real Debrace Date 18th June 2013
Thanks nikkibabie19, I agree. It's just so damn frustrating when they move sooo slowly!!
Cheers kennyandrew85. I've attached another pic. I see what you're saying but I think the tooth looks smaller because it's actually not flush/straight i.e. it's rotated away from the straight tooth. What do you think with this second pic where you can see how it's slanting backwards?
I think that when it's rotated it will be flush with the other tooth (I hope!)
How about a pic from the angle showing the arch itself? Open your mouth and take the pic from the direction of your chin. That might be a better guage of whether the teeth are straight or not...?
385 Days in Damon Braces
It's funny because the arch looks fine but aesthetically it's still crooked (see pic 2 - the tooth is going back at an angle) If you follow the bottom of the good tooth in pic one across horizontally, when you get to the "bad" tooth, it goes back at an angle. Hmph
Here's another pic - you can see that (aesthetically) it's not flush with the straight tooth beside it....the left corner is raised and then it is bent backwards (it looks like the tooth is smaller but it's the angle at which it's rotated at)
Thanks everyone. I really appreciate your feedback. I'll see how I get on, feel very disheartened as my two front teeth aren't flush and there's an inconsistent gap between them. I'll see how I get on and post my results when I have the brace off.
I see what you mean...particularly in that last picture. But since that tooth is either chipped or ground down at an angle anyway, it will probably need bonding. Maybe it is something that can be easily covered up when it is bonded?
