Plleeasse tell me how long these bands & hooks on will hurt
spudly
#1 Post by spudly »
:-(( it has only been 3 days I know I know
Every post I read say that it takes a while :-((
The brackets don't hurt at all but how is it possible that my tounge and cheeks will get used to these really sharp wires and HUGE hooks ? How long does it normally take :?: days weeks months ....
Maybe if I prepared myself for a time in mind it would help me stay positive :Questions:
At comments , support, anything ,,, I can't stand the idea of waking up again tomorrow feeling like I slept with a cutlery draw in my mouth :roll:
Age 48 years young
bands to be fitted 15th June
Bottom metal braces fitted 22nd June
Top ceramic fitted 20th July
batwing
Re: Plleeasse tell me how long these bands & hooks on will h
#2 Post by batwing »
It took about a week for me. Days 2 and 3 I had to use the most wax on my bands, and I had one day about three weeks in where I had a lot of movement and had to add wax on one of my front brackets that kept catching my lip.
Hang in there! I have days where I forget I have them, you'll get there soon too.
Central Ossifying Fibroma removed from mandible 3/8/2012, braced 5/24/2012, One piece Le Fort I performed 12/11/2013, debraced 8/26/2014
nikkibabie19
#3 Post by nikkibabie19 »
If the pain is too much you can always use a painkiller...My pain wasnt that bad after the 2nd day.
It just use to hurt when i ate (chew)...but other than that no pain to talk about.
FINALLY Me after braces : http://www.archwired.com/phpbb2/viewtop ... 13&t=46650
[/color]
AM21
#4 Post by AM21 »
It took about a week for me as well. Wax was my bestfriend until my mouth toughened up a bit. Glob wax on the bands and hooks that are causing you the most pain. It might not seem like it right now but you will forget about your braces in time.
Even after having braces for a while, I still have moments when I have to bring the wax back out, to cover a bracket or wire that's irritating my cheek.
Just hang in there, things will get better. =]
Braced: August 1, 2011
Sentence: 30 Months
My Braces Blog: http://www.metalmouthtales.blogspot.com
spudly
#5 Post by spudly »
:flowerbloom: thank you all for your words of encouragement and support
It seems hard to imagine that the sharp wires will stop hurting so much
I have got better at putting on the way so it stays put for the day :D just as well as I am paranoid about it falling off and me choking on it !
What am I like eh,
I am still so pleased I took the plunge and just need to get through this !
First day at work tomorrow :paperbag:
Age 48 years young
AltoRose
#6 Post by AltoRose »
Mine took just over a week before they stopped hurting. I remember thinking it would never get better, because it hurt to chew SO much and I was going through so much wax. Eventually, though, your mouth just toughens up. I'm at two weeks tomorrow and I've gotten so used to them that I almost forget they're there.
Second go-round with braces! Age: 32
bravesweety
#7 Post by bravesweety »
I've had my upper damon clear braces for almost 3 weeks. In about a week I found the hooks and brackets stopped hurting me. I tried to only use the wax when it hurt, so that my mouth would toughen up. I got my molar bands a week after I got my brackets and wire. I found that molar band more uncomfortable than the actual brackets. I did a lot of research to see if it was normal for the bands to cause pain. My tongue was really irritated by the cleats on the band and I thought it would never get better, but after 4 or 5 days I noticed that I wasn't having any pain and didn't really notice the cleats anymore. Hope you are getting used to the hooks. Just think about what your teeth will look like and remember that it does get better :)
BracedInNOLA
#8 Post by BracedInNOLA »
If you're using enough wax that you think it might be a choking hazard, I think you may be using too much wax on each bracket. It should definitely be smaller than most multi-vitamin pills that you swallow.
Mine didn't hurt for too long - and I resisted using wax initially so things would 'toughen up' - but every once in a while the back ones irritate my cheek in such a way that wax for a day or so is a god-send.
spudly
#9 Post by spudly »
Thank you all for your advice and support, It is now 5 days and a tiny bit better. I do have to still use wax but I will try to use less as you suggested. This could help with the chipmunk look :|
I am counting the sleeps now thinking when I get to two weeks it will be LOADS better ! Gotta think positive right !
Still can't actually believe the SIZE of the hooks !!
Well first day at work and my close colleagues said "let's have a look" I found it better just to show them and get it over with ! And even pro actively showed it to others
I find it a tiny bit hard to talk from time to time but think this is because it is sore and meeting after meeting of talking makes it sorer ... Is that a word !
I am still a little apprehensive if how I will be when the tops get done but really excited how it will start to look ...
I really enjoy looking at your stories and photos ... I have tried to load mine but it is notan easy task
Will persevere as they helped me so much I want to help others
:tingrin:
Age 48 years young
spudly
#10 Post by spudly »
:lol:
Just a quick update folks !
LOADS better today ! whoo hooo
the body is an amazing thing eh ! to get used to the stuff we throw at it
now I just have to work out how to do the photo's so I can share with you all my progress !
Age 48 years young
starfish88
#11 Post by starfish88 »
Glad its feeling better. Its given me hope that I won't be in pain forever! Plus I agree with the proactivly showing people at work so they can dicuss it for 2 minutes then forget theres anything different about your teeth. It worked especially well for me as I work with little kids and they were all really curious but after they had seen them once they didn't care. Can't wait to see pictures
16 months 1 week and 2 days in braces
12mm overjet and narrow jaws all fixed with braces and elastics.
http://www.archwired.com/phpbb2/viewtop ... =9&t=42441
spudly
#12 Post by spudly »
:huh: today I had salmon and rice and NO ....NO need for wax all day !!
Age 48 years young
