Flossing tip.
Duncan5
Flossing tip.
#1 Post by Duncan5 »
Found it's much easier to thread the floss past the wire if I fold over the first couple of inches and twist it together. The double thickness is stiffer so easier to control and grab the errant end. Then I can unfold it and floss as normal.
No threaders in any of my local chemists, but this does help.
trisportgirl
Re: Flossing tip.
#2 Post by trisportgirl »
Good idea, thanks for sharing! I'll definitely use this if I can't find my threaders.
Braced on November 1, 2011
Debanded on November 9, 2012
Permanent retainers top and bottom + Hawley top
Glandyover
Re: Flossing tip.
#3 Post by Glandyover »
I'd been using flossers before braces so I looked for some that would work with braces and finally found them. Man, they make flossing so much faster than threading!
BraceFace2o1o
Re: Flossing tip.
#4 Post by BraceFace2o1o »
Good tip if you are not able to get your hands on any floss threaders :D
I LOVE my floss threaders, they have made threading floss so much easier. I couldn't be without them now and have stocked up on way too many :lol:. They are going to come in very handy when I need to floss the teeth attached to the bonded retainer
Myteeth
Re: Flossing tip.
#5 Post by Myteeth »
Anyone know where you can get a floss threaded from in the UK? Haven't seen any in Boots etc. x
BraceFace2o1o
Re: Flossing tip.
#6 Post by BraceFace2o1o »
Myteeth wrote:Anyone know where you can get a floss threaded from in the UK? Haven't seen any in Boots etc. x
You can buy Oral B Superfloss in the UK. It is sold on the Boots website but maybe some smaller Boots stores don't stock it :? http://www.boots.com/en/Oral-B-Superflo ... loss_1048/. Maybe try some local chemists. If not then you can buy it online from Amazon or other UK sites. When I bought my pack of Oral B Superfloss I couldn't get on with it, it was just too thick and wouldn't fit between my teeth, but some people seem to be ok with it so it's worth a try.
I just use regular floss and a floss threader to thread it under the wire.
I have not seen any floss threaders sold in shops here in the UK so I have to buy mine online, I get them from eBay as they normally work out cheaper. You can also buy them from from Amazon etc http://www.amazon.co.uk/DENTEK-FLOSS-TH ... B000TBZ0CI. I am not sure if I am allowed to post these links so they could get removed.
These are the exact floss threaders that I use:
