Which does everyone recommend to be the best cleaner? A Waterpik or an Airflosser?
I find that I'm not doing a good enough job with flossing between my molar bands and they occasionally bleed whan I floss. I've decided to try something new to get my gums into better health!
So which do you recommend guys? Or... Is there something even better than these?!
Waterpik or Airfloss?
Four wisdom extracted 03/2011, Braces & quadhelix 09/2011, bimax & genio summer 2013
Blog: http://jawsurgery-journey.blogspot.co.uk
Vlog: https://www.youtube.com/user/doublejawsurgery/videos
Re: Waterpik or Airfloss?
I love my waterpik water flosser. I can really tell a difference in my gums and when I floss...honestly, Here lately my routine will be to use the pipe cleaner in between my brackets, then I will use my waterfloss, then I will floss, then brush. when I use regular floss, I honestly find that there is hardly anything that comes out. I go to the dentist tomorrow for my cleaning, so we will see what the doc says.
I've never used an Airfloss but I do have a Waterpik and I love it. It's great for getting everything out from around the molar bands. I use it before flossing and I hardly find any stuff on the floss. It feels good on the gums too.
I have a waterpik too and it's great. Really helps with the itchy feeling after adjustments!
16 months 1 week and 2 days in braces
12mm overjet and narrow jaws all fixed with braces and elastics.
http://www.archwired.com/phpbb2/viewtop ... =9&t=42441
I love my waterpik. I use it before flossing and there is hardly anything that comes out as if I floss first there still things that comes out when I use the waterpik. I think it will be a great investment!!
I came across an article about waterfloss being significantly better than airfloss.
Thanks for your replies guys, I ordered one
I think the waterpik is supposed to be stronger (more effective) especially for braces where food can get stuck in more places than just between teeth/gums. I bought the basic waterpik which works great, but make sure you keep it plugged in. Had it for 3 months, somewhere in there let it sit without charging for 2 weeks and then it was dead. Called waterpik and they sent me a replacement one though! Good to know they're willing to provide good customer service if you have a problem.
My upper jaw surgery blog
