*Superfloss
* A SUPER soft toothbrush. Normal soft one's hurt my gums a lot.
* Soft foods you like (I ate tinned spaghetti, tomato soup, custard, LOTS of yoghurt, smoothies are good, pikelets are good once you can chew a little, pasta is handy).
* Sterile Gauze-I've had zero luck with my silicone wax. It....just....won't...stick so when things get tough I chuck some gauze in between my brackets and my cheeks and it helps the ulcers heal (I use it in conjunction with kenalog for really bad ulcers that won't get better-thankfully not many of these-and braces relief or bonjella-someone on here mentioned it to me when I was miserable not that long ago).
*Panadol (paracetamol).
*Piksters (tree toothbrushes).
*Dry mouth mouthwash-day 2 my braces and mouth felt SOOO dry. Lasted about a week and a half. I thought it would never end, but it does and things go back to normal
