I am getting my braces OFF next wednesday and I was wondering if I would be able to get my teeth bleached right away.
thanks
Can I get my teeth bleached RIGHT AFTER I get my braces off?
RPE. 6/5/2010
Full metal braces, 8/7/2010
Braces Removed, 6/12/2013
Re: Can I get my teeth bleached RIGHT AFTER I get my braces
Sure. Some teeth might be a little sensitive, but using sensitive toothpaste and some flouride mouthwash should reduce that.
My upper jaw surgery blog
That's a good day to get them off! I'll be doing the same thing Wednesday, June 12th @ 0800.bottlecap1990 wrote:I am getting my braces OFF next wednesday
CONGRATULATIONS TO BOTH OF YOU!!!!
I started the highest grade Crest White strips the day I got mine off. No problems at all and very glad I did!!
My ortho is whitening mine right after the braces come off Cant wait, though its probably going to be another year!!
