Wires Changed - Ouch!
My orthodontist changed both my wires this morning. She was having trouble with the bottom one and was really tugging, I thought she'd either dislocate my jaw, pull my teeth out or both! She apologised and I know this can happen but I'm in pain now. Back to soft foods for me today and hopefully my teeth will be less painful tomorrow. Seen a lot of progress since September so it will be worth it in the end.
Re: Wires Changed - Ouch!
My first wire change was YOWWWWWWWWW! They have been less painful after that.
My first wire change was ok so I wasn't expecting it to hurt yesterday. Still sore this morning but hopefully it will ease during the day.beckyboo0205 wrote:My first wire change was YOWWWWWWWWW! They have been less painful after that.
- mysticgirl916
I got my first wire change a couple of days ago, they were a little pokey when they were put on but the hygenist trimmed the ends so I'd feel more comfortable. I'm adjusting to the adjustment right now (it hurts a little), nothing that a little ibuprofen can't fix
I wish I could tell you it gets better, but it really doesn't. I've found that each adjustment day will bring me a good bit of discomfort later in the day and it will usually last about 48 hours depending on what is done. Just a change of ligs is no big deal. In my case, addition of a power chain, change of wire strength or change of elastics config is always sore for about two days and then it calms right back down again. Taking some Tylenol about an hour before the appointment and then keeping up with the recommended dose the rest of the day helps a lot as does easing back to softer foods for a day or two. The good news is that it's short lived. And, pain = progress.
Thanks, I shall be prepared from now on, as my first wire change was completely pain free I wasn't expecting it to be that bad. It's much better now and no pain no gain as they say.kathydell wrote:I wish I could tell you it gets better, but it really doesn't. I've found that each adjustment day will bring me a good bit of discomfort later in the day and it will usually last about 48 hours depending on what is done. Just a change of ligs is no big deal. In my case, addition of a power chain, change of wire strength or change of elastics config is always sore for about two days and then it calms right back down again. Taking some Tylenol about an hour before the appointment and then keeping up with the recommended dose the rest of the day helps a lot as does easing back to softer foods for a day or two. The good news is that it's short lived. And, pain = progress.
I got my first adjustments and power chains yesterday and gosh that hurt. Tried sleeping but kept waking up because my jaw would just snap and close hitting my sensitive teeth. My cheeks are sore. Orajel kinda helped for a few minutes only. Tylenol didnt really much at all. I guess the only highlight of that 1st adjusment appointment for me was I saw the gaps closing in as soon as I got home. Other than that, Im miserable.
- BraceForIt
I had my first adjustment 4 days ago. I had most of the pain and aches on the day of the adjustment, the next day it was fine
Upper: removal of my powerchain, was not replaced however the archwire was replaced with a thicker one
Lower: change of archwire along with the addition of springs
One thing i noticed was about 20 minutes after i left the Orthodontists office, I heard the loudest crack/click followed by a quick jolt of aching pain from one of the lower teeth attached to one of the springs. I was super suprised by this! the springs were straight away to action i guess
No serious pain from that tooth from then, it was just noticable that moment!
I got my first set of SureSmile wires on Dec. 9th. They pretty much hurt for 5 straight weeks, albeit in different places.
Got my 2nd set of SureSmile wires on Jan. 13th. They are a stiffer wire, and probably won't get changed for several months, and I hurt in places it didn't previously hurt.
My biggest issue is the lack of a bracket or band on #6 on the upper left. Wire bridges a lengthy gap, and chewing anything on that side makes the wire shift so I get pokey bit on the #6 on upper right (#7 is a gold crown and has no band or bracket).
Seen some significant changes in my bite over the past 3 months, more the last 5 weeks than the first 7 weeks.
Seeing as how treatment #2 straightened my teeth, there isn't much straightening to do, just fix my bite.
The good thing is that my bathroom scale doesn't say Errr! anymore, because I have lost enough weight to be back under its limit.
Strangely my first adjustment where they put wire ligs on my original wire hurt more than my new wire (+ wire and rubber ligs!) this week.
Still slightly tender to bite after 3 days, but I can manage chocolate as long as it hasn't been in the fridge, and that's really all that matters!
I have had my braces for a little over a year, and have not had too many wire changes. However, I just take an aspirin eat something for that day and the pain normally dissipates the next day.
I do too!Matilda wrote:I might be the only one but I love feeling the adjustment pain.
Ibuprofen is great for dental pain.
My theory is that for most of us, pain from orthodontia is a relatively new experience, and as a result we are a bit anxious which heightens the pain experience. After a while we become accustomed to the (mostly) temporary discomfort that follows a new wire arch or addition of some new device and recognize it as progress, not a sign of pathology, and can cope better. I have lots of hare-brained theories, of course.
