I cant see any difference on my smile I think it actually looks worse than before I will post a few picture I'm starting to think this was a big mistake I feel horrible not been able to eat or smile my teeth are huge now. And I think my overbite is bigger now![]()
8 months and no change
Re: 8 months and no change
Sorry to hear this. Eating and smiling do get easier. Are you sure there's no movement? Sounds like you should have a chat with your orthodontist, they may be able to say what they are expecting at his stage & if you are on track. Pictures will often help.
1st Feb 2012 - extraction both upper 2nd premolars
Braced 9th March 2012 - lower metal fixed and upper removable plate
5th September 2012 - bite plate gone, upper ceramic fixed fitted
Estimated treatment time 18-24 months
I got extractions and they are closing fast he told me that it takes time because he have to move my teeth once by one I see progress on the holes from the extractions but my overbite is still theresmilehope wrote:Sorry to hear this. Eating and smiling do get easier. Are you sure there's no movement? Sounds like you should have a chat with your orthodontist, they may be able to say what they are expecting at his stage & if you are on track. Pictures will often help.
- MrsCharisma
This is the life of orthodontics. It'll start to change...eventually.
I had a 5 mm gap in between my front teeth close within 2 months. The 1 mm gap formed by that closure? Nope. Won't close. It's been at least 3-4 months but NOTHING.
*eventually* something will happen.
Female, 34
Sentence: 18-24 months
Ceramic uppers, metal lowers
i know i just get discourage because he always say lets puch those teeth back !! and i get happy but one month later nothing and i have to be patient i have one more year to go hopefully it looks better .. thank you so muchMrsCharisma wrote:This is the life of orthodontics. It'll start to change...eventually.
