excess glue
excess glue
just discovered that i have excess glue under my molar tubes reaching my gums. I had them put on my last adjustment a gew days ago. Will it be harmful to my gums? Can i scrape it myself? I am scared to losen the tubes if i try to do it myself. I am so ... disappointed i heard the ortho telling the assisstant: that is too much glue but he just yhen changed the subject and they didn't do anything about it!!
Re: excess glue
I don't think it's an issue unless it has a jagged surface catching food or if it feels like there's something jammed down in there (I don't know how close your bands are to your teeth.) It's more of a problem on teeth where you can actually see it.
I guess the question is: Would you have known about it if the ortho didn't mention it?
Certainly don't try and pick away at it yourself.
Re: excess glue
It shouldn't be an issue. You can get it taken care of at your next adjustment if it's really bothering you.
Re: excess glue
It will wear off once you start eating .. Takes about 4-5 days .. Chew some gum or tell ur dentist about it. That's her job!
Re: excess glue
Thank you Sirwired, Chichi, and Roxie. I appreciate it I thought it might be silently hurting my gums or something but it's not bothering me at all. Happy it's not urgent.. will tell my ortho about it at my next adjustment.
