Anyone have elastics pull off brackets?
oldfart
#1 Post by oldfart »
Just my new paranoia. Just curious if anyone has put in elastics and like yawned or openned thier mouth too wide and pull off the bracket it was attached to?
Just curious.
bjohnson207
Re: Anyone have elastics pull off brackets?
#2 Post by bjohnson207 »
I would say that you should be snapping rubber bands long before a bracket comes off. And that hurts!!!
oldfart
#3 Post by oldfart »
Just asking as i want to put onlike 4 or 5 to GET THESE TEETH TO MOVE MORE!!! Okay, just kidding. I feel better thats out of my system.
of
sirwired
#4 Post by sirwired »
The forces exerted by rubber bands are trivial compared with chewing forces.
DrJasonKTam
#5 Post by DrJasonKTam »
Just a caution that more force on the teeth does not always mean more and quicker movement.
There is actually a threshold of force which when is exceeded, will actually slow down the movement of the teeth and cause issues with the roots.
That being said, if you are using your regular elastics, the brackets should not come off.
Dr. Jason Tam
http://www.mcosmiles.com
monkey123
#6 Post by monkey123 »
I was told you can also damage the roots if you put too many on
oldfart
#7 Post by oldfart »
I haven't. Just because I want to, doesn't mean I am insane enough to do it.
oldfart
#8 Post by oldfart »
I cursed myself. Had a hook come off while yawning. No I wasn't wearing multiple elastics on it. This is just a small wire created hook attached to a bracket. My office calls them THIS IS SPAM PLEASE REPORT TO ADMINISTRATOR THIS IS SPAM PLEASE REPORT TO ADMINISTRATOR THIS IS SPAM PLEASE REPORT TO ADMINISTRATOR THIS IS SPAM PLEASE REPORT TO ADMINISTRATOR THIS IS SPAM PLEASE REPORT TO ADMINISTRATOR hooks. I bent it down while brushing too quickly, bent it up, and it lasted two more days. Them came off taking the ligature with it. I got the lig back on, and was able to get in this morning to have one put back on. (Yes I took them snacks.)
of
