Hi, haven't posted for a while but have decided (I think) to take the plunge. Booked my appointments today and she is starting with expanders. Totally freaking about the whole thing one minute and whether the whole thing will even work and the next thinking got to address it at some point. I'm 35 and gonna have full on braces, TADs etc. sometimes get too scared to even read about this so go easy but be honest
Didn't ask half the things I wanted to but thought some of you may be able to help.
What's an expander? Does it hurt like hell? Next she said was elastics? Got plenty more questions I'm sure. This is for open bite so appreciate any comments from you open bitters who have gone or are going through this.
Thanks
Expander?
Re: Expander?
I'm getting an Expander as well on Thursday and dreading it. I have a crossbite, which is caused by a very narrow upper palate. The expander is going to be used to expand my palate (by about 7 mm) so that my upper teeth fit over my bottom teeth. Right now, my upper teeth fit inside my bottom teeth (crossbite), which is causing premature tooth wear. You may want to find out what exactly it is she is trying to accomplish because Expanders don't work well in adults without surgery. I had surgery 3 weeks ago, which is why they are starting on Thursday with the Expander. If you only require minor expansion, then I think it will work without surgery. The big problem with the Expander is that it is cemented in your mouth and it can affect your speech initially until you learn to speak with it in. Then it stays in for 6 months. Again, as I said, I'm dreading it. I'll update later in the week with how I'm coping.
Re: Expander?
I had an expander as a kid and it was painless.
Elastics are a part of most braces... They range from a mild annoyance to a real pain in the !bleep!.
Re: Expander?
If you really want to see a pic of what your ortho's talking about do a search for palate expander. There's a couple different options or styles of them.
Re: Expander?
I had an expander as a teenager. It was kind of like a retainer, but cut in half and with a screw in the middle of the bit on the roof of your mouth. I had to turn the screw every day/week/whatever until they'd expanded my upper jaw to where they wanted it.
I don't remember it hurting particularly, but you do get some pressure as they push things around.
This was about 20 years ago, so I'm sure they have all sorts of new versions now!
I liked that mine was removable though, so I could take it out to clean it etc.
Re: Expander?
I have had an expander in before I got my braces. Had to have surgery for it to expand my palate. I still have our in now with braces. The only pain you may have is when you tighten it.
You'll eventually get used to it, especially if you have it in as long as I have.
