Tightest rubber bands ever!
ITALIANNYC
#1 Post by ITALIANNYC »
Hey everyone.
Been in braces for about 3 and a half years and now we have come to the end of the journey. I have used rubber bands before but then I did not need them anymore. Now we are at the end of the treatment where he says I need to wear them again for hopefully only 1 month, though it could be two. Then he said I am done besides just adjusting a tooth here or there. Done by the summer.
Boy oh boy, I usually was using the LION rubber bands which are 1/4 6.4mm Medium
Now he put bands from canine to canine to pre molar to premolar. I basically have an M shape on both sides of my mouth. These bands are ZEBRAs which are 3/16 4.8mm Medium. That are smaller than the old ones and wow these are strong. I can't no open my mouth at all really. I can't stick my tongue between my teeth very much and I can't even lick my lips lol.
I use to eat with the bands in, well NOT ANYMORE, not with these bad boys, I can't even put something in my mouth.
I guess since this is the end I have to deal with it but man do I feel like my mouth is wired shut.
Tyrantblade
Re: Tightest rubber bands ever!
#2 Post by Tyrantblade »
Thats how i felt when i first started wearing Rams (which are thicker and stronger than Zebras) in triangles
You will get used to them and then it wont be so bad
Lots of crimes here
3. Open bite
Braces removed since 11/06/17
Felina Grimm
#3 Post by Felina Grimm »
I started with Cheetahs (extra heavy) and I felt the same way. I couldn't open my mouth. But after several days, I was able to open it just fine. Your body will adjust to the new strength. :-)
Sentence: 24 months, months served: 35 months
Traditional Full-Metal Brackets
Top: 9/9/2014
Bottom: 10/15/2014
Debonded: 8/7/2017
LongJourney
#4 Post by LongJourney »
After a week, you'll probably be able to eat in it. I'm wearing the sea lion-heavy- and at the beginning, I'm like... So guess I'm going to be on mute for couple of days
And now I can open my mouth easily and eat in it.
It'll get better and congrats, you're getting released soon :thumbsup:
