Foods that stain clear ligatures?
So I just got a clear powerchains put on, I was wondering if anyone had any tips as to which foods/drinks to avoid and how to prevent it turning yellow? Thanks!
Re: Foods that stain clear ligatures?
I am a coffee drinker. I purchased straws that are meant to be used for hot liquids. This helped big time in keeping the power chains looking cleaner longer. They will yellow anyway In between appointments until you get them changed. I have heard curry will stain really bad so avoid that. Good luck!
Braces installed October 2, 2014
Braces removed May 17, 2016
I have learnt the hard way that tomato based sauces stain the power chains a horrible almost neon green colour!
As well as the usual (curry, coffee, red wine, tomatoes, blueberries, etc.), beware of chocolate! No one warned me about that! Make sure you use mouthwash straight afterwards and brush as soon as you can.
