I got my braces off today after I started treatment almost 2 years ago and had braces put on 1.5 years ago.
My teeth look ok - although the arch is a bit disturbing to me - seems severe compared to what I had before and now I can feel my front upper teeth rub against my inner upper lip - making me feel like I have buck teeth although I don't. But the illusion to me is disconcerting.
Add to that - my bite is odd - I have contact on both sides from the back of my mouth all the way to the canines AND even my lower front teeth touch the back of my upper front teeth.
Is it because my original teeth didn't touch much (although looked "ok") and now they are in the right position OR is this NOT ok - and I need an adjustment?
I go back for a bit more polishing and shaping on Tuesday and to pick up my retainer.
Thanks in advance!
Braces off today - looking good feeling weird
Looking forward to the new smile,
KayKay
KayKay
Re: Braces off today - looking good feeling weird
Well, from what you are describing your bite sounds right. All molars should touch and the front teeth should also touch lightly. ( bottom teeth behind upper teeth ). And with your front teeth rubbing against your lip, maybe it feels strange without the brackets?
Congratulations, im about halfway through my treatment, still (roughly) a year (hopefully not much longer) left to go
Lots of crimes here
3. Open bite
Braces removed since 11/06/17
3. Open bite
