Need help with braces
Xela
#1 Post by Xela »
Hi all! I've been wearing the metal braces for about 1.5months so far. I've gotten it due to multiple gaps between my teeth, which are deemed small by almost every dentist I've visited. There have been a few problems so far and I've been hesitant to ask my dentist directly as I don't wish to seem to be rude.
1) Do all cases regarding braces need to be reviewed by an orthodontist? I recently found out about the differences between an orthodontist and a dentist. Turned out that they used to have both, but the orthodontist has since left the Clinic. Will that affect my case a lot?
2) Today, another bracket fell out again, and this has happened two times so far. I used to be a teeth grinder but it had stopped when I put on my braces. Thus I was shocked when it fell out when I woke up. The first one fell out when I was eating soft chicken and rice. I don't mind the bite blocks but I realised that they get worn down very quickly. Should I ask the dentist to put on a larger amount of clay to prevent another bracket from falling out? What are the other things I can do?
Armbomb
Re: Need help with braces
#2 Post by Armbomb »
You always want an orthodontist over a dentist. Orthodontists specialize in teeth alignment and malocclusion. They need a few more years of schooling for this. You don't go to your regular doctor if you need heart surgery (just an example, I realize teeth alignment isn't terminal)
Losing brackets at the beginning of treatment is normal. Are they front teeth or back? You would not want them to put more composite on the bracket just to ensure it won't fall off, that won't help. If it's the back teeth isolation is usually why the brackets pop off, it's rather hard to keep them dry during the curing of the bracket.
I work at an ortho office and I myself have had 4 detached brackets and I've been in braces for 4 months. Depending on which brackets pop off, it won't delay your treatment.
