How far can my teeth be pulled down
shanlola
#1 Post by shanlola »
Hi all, just a quick question, I have a couple of teeth which are shorter than the rest, due to grinding my teeth and wearing them away! I wonder how much is my ortho able to pull these down? I'd say they need maybe 3mm to be inline with the rest, is this do able? Thank you .
geeky1978
Re: How far can my teeth be pulled down
#2 Post by geeky1978 »
Yes, this is one of the easiest and fastest movements that happen with braces. As long as there is enough root, it will be fine.
