Bite Stoppers
IssaAnon
Bite Stoppers
#1 Post by IssaAnon »
Hey guys I just got braces put on October 2nd. The ortho put bite stoppers on my first molar because i have a crossbite. I'm assuming its so that I don't accidentally bite my braces off. Am i correct in assuming that the bite stoppers will come off eventually after my bite has been fixed? Or do bite stoppers stay forever?
FlyByNight
Re: Bite Stoppers
#2 Post by FlyByNight »
Mine were behind my upper 2 front teeth. They came off less than halfway through treatment. They are to prevent you from damaging your braces.
Bracingmyself33
Re: Bite Stoppers
#3 Post by Bracingmyself33 »
My dentist calls them "blue mountains" because the the material is in blue.
I had mine at my molars to prevent my top teeth from knocking off my bottom braces and had them for around 3 months.
I supposed the duration varies person from person. A friend of mine with overbite had stoppers since day 1.
Tyrantblade
Re: Bite Stoppers
#4 Post by Tyrantblade »
Ive had them for 8 months; they rebuilt them a couple timrs, and then they got rid of whatever didnt just wear off over time.
Lots of crimes here
3. Open bite
Braces removed since 11/06/17
tmjd
Re: Bite Stoppers
#5 Post by tmjd »
Indeed, they are to stop you from biting your own braces one with another. I found a lot of support here, it's been almost 2 weeks and I am past the panic stage, up to acceptance stage. Chewing with them is tricky. My guess is your ortho removes them once you are safe from biting your braces together, so, it depends on each bite.
dianaioanab
Re: Bite Stoppers
#6 Post by dianaioanab »
Trust me, they are a blessing in diguise. I was kinda panicked at first, but i got used to them and they also got flatter pretty fast. I actually wish they were a tad bigger (wish my ortho had rebuilt them) because i keep touching a bracket when i bite and the tooth is starting to hurt preeeety damn badly.
