Braces only on 2 front teeth to create a gap before sarpe surgery
Jaydee83
#1 Post by Jaydee83 »
So on Thursday I had 2 white brackets fitted on 2 front teeth with a small wire and a spring that will open a gap between the teeth so my surgeon can separate my palate has any had this? As you can see my midline is way off which causes alot of tmj issues
