Seriously? Bracket fell off already - 2nd day
marathon
#1 Post by marathon »
Ugh, it's only day 2 and I already dislodged a bracket. :( I was eating, but nothing weird...just some soft bread and cheese in small pieces. It's a Saturday so I have to wait until Monday to call them. It's so annoying, the bracket is just floating there on the wire and keeps getting turned around.
It's a tooth that's set back a bit from the ones on either side and slightly stained as a result. Maybe that one's going to be a problem?
Carno
Re: Seriously? Bracket fell off already - 2nd day
#2 Post by Carno »
I wouldn't worry too much about it, I had the same thing happen to me a couple days after getting braces on. Sounds like the tooth was in a similar position to mine as well, but after getting the bracket put back on, I've not had any more issues.
raph
#3 Post by raph »
Don't worry! It happened to me twice on the very first day, and never again.
I had my braces put on in the morning, and I chose the softest thing from the work cafeteria for lunch. I lost three brackets on lower (pre) molars at once.
Went back to the orthodontist, they put them back in, with a thinner wire than before, added a rubber thingy on the tooth that was the most out of alignment, and I went back to work. I was still hungry, and the next thing I ate also made me lose one bracket.
I went back in the evening and they added resin dots under my molars on both sides to prevent me from biting on the bracket. The tooth shifted fast enough that I only needed these resin things for a month, and I've never lost a bracket again (it's been 8 months).
Badbiteguy
#4 Post by Badbiteguy »
Ha! I’ve just had the same thing happen to me on day 3. My orthodontist had trouble initially attaching the brackets to a couple of crowns I have and it looks like the same bracket has come loose. He wasn’t to phased when I rang him today and I going back in three days to have it refixed.
marathon
#5 Post by marathon »
It's been over a month now--no further issues! Whew.
djspeece
#6 Post by djspeece »
marathon wrote: Fri Oct 02, 2020 9:16 pm It's been over a month now--no further issues! Whew.
Don't jinx yourself! :lol:
I had the same issue two days into treatment, eating yogurt of all things. Lots of bad words were uttered that day.
Best of luck to you!
