for those with an off midline
Just curious for all of us with and off midline, how far is yours off, and what and how is it being corrected?
Thanks for any responses
Leah
Here's a pic of mine,
[img][img]http://img264.imageshack.us/img264/1834 ... 4rw.th.jpg[/img][img]
Leah
lower wisdom teeth cut out 1/27/05 (ouch)
braced 3/8/05.
24-30 month Est.
going full metal 8/22/05
Naked as of August 28, 2006
braced 3/8/05.
24-30 month Est.
- HollyDontSpend
Midline
Not sure how far mine is off, but it has been corrected though use of elastics. I've been wearing them since November of last year. It's worked pretty well, but it's still not completely perfect. Actually, I never noticed that it was off, given how crooked my teeth were. HA!
Damon 2's for 18 months, removed 11/03/05
Dear Leah,
I had the following elastic configuration to correct my lower midline :
It needed to move almost one lower incisor's width. And yes, this rather
... annoying ... configuration did work well. I had it for about 6 weeks.
The rest was done by normal elastics. I mean those that are hidden a bit
better. But I see your issues are mainly the upper teeth. I guess this is
harder to correct.
harder to correct.
thank you
Thanks for your replies, just seem 1 elastic is not going to do much. and Clo that is some configuration.
Leah
Leah
braced 3/8/05.
24-30 month Est.
braced 3/8/05.
24-30 month Est.
My ortho told me my top midline if fine, its just the lower we have to worry about-I imagine I will have some sort of set up like Clo does when my time comes!!
Spacers-9-19-05
Top Braced-10-03-05
lowers on-10-17-05
appliance installed in mouth 10-17-05
2 extractions on 8-3-06
2 years treatment time
Dr says I won't finish on time
Top Braced-10-03-05
lowers on-10-17-05
I didn't have a clue about the midline...so I was not aware that my was off...but I guess mine was not that much off. As it is nearly corrected now!!
without any elastics, my teeth were slandirized
6/4/2005: 2nd premolar extracted+ spacers in
6/13/2005: clear braces: top and bottom
next 'date' on 18th Nov. ...and the bottoms might be off then?!:-) top will stay until Dec. before xmas.
midline
Bracingmyself, My midline was perfect before I was braced, from what I understand it is pretty common to have it be off sometime during treatment, especally if you have to have front teeth work done.
Leah
Leah
braced 3/8/05.
24-30 month Est.
braced 3/8/05.
24-30 month Est.
midline
Yes it should go back just fine with the help of lots of hours in elastics, I guess im my case things had to get alot worse before they could get better, and not im well on the road to better. you can ask you ortho what he "guesses" because thats all they can really do, about wether your midline will be thrown off.
Leah
Leah
braced 3/8/05.
24-30 month Est.
braced 3/8/05.
24-30 month Est.
Well, thinking about it, it figures that it would be off at some point as the teeth are moving but fingers crossed it goes back. I'm sure ortho's want the best result and will work to fix it.
I am going back in 2 weeks to see the models of my simulation she is doing for me so I will ask then.
Thanks
Thanks
midlines
Hey ladies, I asked my ortho about the whole midline thing and he says that why Im in elastics now which I allready knew. Just a very slow process he cannot even guess how long it will take to correct this. but it one of those things have to get bad before they better deals.
best wishes,
Leah
best wishes,
Leah
braced 3/8/05.
24-30 month Est.
braced 3/8/05.
24-30 month Est.
