J HOOK HEADGEAR
J HOOK HEADGEAR
I WAS TOLD THAT I WOULD BE GETTING A J HOOK HEADGER AT MY NEXT APPT. DOES THE J HOOK FASTEN DIRECTLY TO MY ARCHWIRE OR DOES THE ORTHO HAVE TO PUT SOME KIND OF NEW HOOKS ONTO MY WIRE SO THE J HOOKS CAN FASTEN TO IT. DOES ANY ONE OUT THERE WEAR ONE LIKE THIS?? HOW IS IT? HOW DOES IT FEEL?
Re: J HOOK HEADGEAR
hi, sorry can't help you there i wear a reg facebow for my combination headgearBARRY MILLER wrote:I WAS TOLD THAT I WOULD BE GETTING A J HOOK HEADGER AT MY NEXT APPT. DOES THE J HOOK FASTEN DIRECTLY TO MY ARCHWIRE OR DOES THE ORTHO HAVE TO PUT SOME KIND OF NEW HOOKS ONTO MY WIRE SO THE J HOOKS CAN FASTEN TO IT. DOES ANY ONE OUT THERE WEAR ONE LIKE THIS?? HOW IS IT? HOW DOES IT FEEL?
braces off 1/31/08 wearing bonded retainers with a nightsplint, will get removable hawleys 2/21/08
hi, I've got j-hook headgear.
My first set of headgear, the ortho welded little wire hooks to the archwire and the j-hooks attached to those hooks. The kind I have now, the hooks attach directly to the wires, they attach right in front of my bottom canines.
As for comfort, its not to bad, I guess, my biggest problem is drooling at night with it on.
Good Luck
Good Luck
TechChick,
If its not smoking then its a software problem
bracefacesteve,
Sorry, I didn't take any pictures when I had to wear the hg. I've been free from headgear for about 6 months now (thank goodness).
When I first posted in this thread, I had hooks welded to the wire, but once the hg moved my teeth back far enough they attached the hooks directly to the wire its self.
I wish you the best of luck
I'll be happy to answer any more questions if you have any.
TechChick,
