I read a lot of posts and can come up with only one thought. That only an expander can give the appearance of a 'fuller mouth'. Can braces do the same thing if the case isn't that bad? I want my molars to be visible with my smile so I'm just wondering.
Edit: Well, I was thinking something different. My arch is wid enough is just my molars are set at an angled position \ instead of a | . You know what I mean. Guess braces will fix it....I HOPE!111
