I only have had my braces on for 1 month (seems like a year) but in my treatment, my ortho said he's going to put on a permanent retainer on both top and bottom after I have my braces off (I only have to have these damn things on for 6 months.) I figured this would be a good move since I'm 26, don't feel like remembering to put it on everyday, and can't lose them.
BUT, the downside is that I STILL have to thread floss through each tooth, am I right? Is there any more to the "down side" that I should be aware of? Any advice on this would be appreciated...
permanent retainer
Yes, you 'get' to floss with floss threaders with the permanent retainers, but the retainers only cover the first 6 teeth so it's not terrible.
The pluses with the bonded retainers (in my opinion) are 1-they are virtually invisible, being on the 'inside' of your smile, 2-they are impossible to lose, and 3-they are more durable then essix and are easier (from what I've heard) to get used to then hawleys. I really like my permanent retainers, personally.
Good luck
Good luck
- HollyDontSpend
ha
I thought my post didn't post! HAHA! There's two of these posts!
Damon 2's for 18 months, removed 11/03/05
